Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
My screen is backlit and my phone chimes constantly while plugged in
I replaced the screen on my phone and now all i can see on the screen is the backlighting, and when i plug it in it chimes constantly. What is going on and how do I fix it? Thanks in advance.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The White screen is famous when the cables where not properly installed on logic board. check your connections. If the everything is in place and same issue check the cable ribbons for any tears, dents, or any damage to the ribbon cable. If the cables look fine attempt restore or DFU Mode Restore and if those fail you might have another issue which is more costly. Check those and if none of those most likely you will have to spend money.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
I agree with Ryan. I have fixed that issue by putting it in DFU mode and wiping the phone clean. Seems like a software issue.
von
irepairseattle, please refrain from placing your URL or links to your own website in the answer. This can be construed as spamming and thus violates ifixit policies.
von
Antwort hinzufügen
Connor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 527
