Zum Hauptinhalt wechseln
Modell A1418 / Ende 2012 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
212 Fragen Alle anzeigen
Change of hard drive at Apple Service center
It seems that it is almost impossible to replace the hard drive in the new iMac but if the hard drive should break I doubt that I would get a completely new computer from Apple or? Therefore it must be possible to also change the drive at a service center or?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The swap is not a question of possibility. You certainly can replace a lot of components inside the machine once the display assembly is out of the way. The only problem is that the display is held in by double-sided foam tape, which much be replaced. In the past, Apple has used hard drives with proprietary firmware. Chances are high that this is still the case, though we haven't looked into it.
War diese Antwort hilfreich?
Bewertung 0
Yes, it is. It's possible to change drive at Service Center.
Bewertung 0
Antwort hinzufügen
Mikael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 2,229
