Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
power button stops working after screen installation
I just replaced the screen on an ipod. I was extremely careful with this installation, and yet now the power button is not working. I see no rips or tears in the cable. The power was off during install. Any ideas on whether there is a way to fix this without a whole new cable?
Update
Nope, no go :(
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
I only get the voice control coming up when I try that. I just had it happen again. Power button working fine. Now not. I used plastic tools for all the areas around the power button, so I don't see how it could short out. This is REALLY maddening.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
have you reset it as sometime you can short something when you change the screen
press and hold the POWER & HOME buttons wait till it turns off keep them pressed till it comes back on this should get it out of safe mode
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I'll give that a try and see if it works!
von
Antwort hinzufügen
Heather B wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 609
