Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Vibrate button doesnt work after replacing headphone jack
After i replaced my headphone jack and turned on my phone. My volume button works and speaker works now while talking on the phone but my vibrate button doesnt work. Anybody knows why it doesnt work? Please help me fast!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The silent (vibrate) switch is part of the Headphone Ribbon cable that you replaced and can be a little tricky getting lined up during re-assembly, I have also seen the switch to be bad right out of the box new, here are instructions in case you haven't already viewed them, I would start by making sure the plastic nipple on the switch inside the phone is properly seated in the steel switch that you manipulate with your finger's, iPhone 4S Stummschalter, if you cant find something obviouse inside your phone then you may need a new Ribbon cable, good luck.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thanks for your advice! btw, how can i tell if its properly aligned? Because my vibrate button can still switch up and down and it makes that click noise when i switch it.
von
Once you have your phone disassembled, you will see a black plastic nipple the diameter of a #2 pencil lead protruding from the ribbon cable silent switch, then if you look at the inside of your silent button you will see a hole for the nipple to fit into, it's easy to miss align the two, if they are fitted together correctly then you may have a bad ribbon cable, good luck
von
Antwort hinzufügen
Jonathan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 211
