Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
No service after auto/manual searching for signal
I cannot get a signal on my iPhone 4s, ios 6.01 baseband 3.0.04.
If I try to manualy sellect carrier, it searches for the available carriers, finds them and when I select one I get no service. Tried calling emergency number without a sim but that failed also, it should have worked. What's broken, where to look first?
Thank you all for reading this.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
I would start with the obvious and cheapest, the cellular antenna, make sure its plugged in correctly to your motherboard, if it is then I would replace it, iPhone 4S Mobilfunkantenne ersetzen also has your water damage decals turned pink, (water damage) if so treat it for that, iPhone Wasserschaden reparieren , good luck.
iPhone Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
iPhone 4S Mobilfunkantenne Bild
Anleitung
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Bewertung 1
Have you tried to set the date and time manually? If you take out the battery on the iPhone (iOS 6.xx) the date will be 1970.. :p
When you have set the date and time, remove the sim card and put it back in.. This should work :)
(you kan also connect the phone to the WiFi to automatically set date and time. Do the same with the sim card, when the time is right :) )
Bewertung 1
as long as all the connectors are connected properly.
I would try the Wi-Fi conect first . the date & time should update & give you signal back.
if this helps please mark as accepted
Bewertung 0
I'm having the same prob no signal and I have replaced the cellular an tenner and mad sure it's connected/plugged in properly. I'm not to sure wot ya mean with this date thing as when I take my battery out and refit it the date and time set correctly ( not to 1970 ) is there any other plug and play parts I should try b4 making the assumption it's a blue inducter coil problem??
Bewertung 0
1 Kommentar:
Do you get the network when searching manualy? The weird thing is I do but when sellecting one, no service!
von
Antwort hinzufügen
daian catalin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,735
