Zum Hauptinhalt wechseln
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
Software component of memory board replacement
After replacing the board does the computer automatically recognize it? Other than physical replacement is there anything else to do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Kevin, most likely you will find that you need to reinstall a few drivers for the logicboard. Those are usually available at the motherboard manufacturers website, and/or you may even get the driver disk with your board. Everything else should be okay. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kevin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 640
