Zum Hauptinhalt wechseln
The Apple TV is a digital media receiver designed by Apple and released on March 21, 2007
Analog RCA Audio not Working
I have the Apple TV 1st Gen and am trying to use the RCA analog audio output, but no sound is coming out. I have tried connecting the RCA cable directly to the TV, into my receiver, and even tried routing it through my computer's audio, but it still has not worked.
I have googled extensively about this problem and haven't found anything extremely helpful.
In case anyone is wondering, I don't have the option of using the hdmi audio, or the optical audio. I have, however had the opportunity to test if the hdmi audio works, and it does.
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Adjust the audio out and dloby digital settings (settings > audio & video)
You might also try restarting the Apple TV by removing ALL the cables for 30 seconds, or resetting it using the reset option under general.
If this answer was helpful please remember to mark it accepted.''
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I tried all these, still no audio. And just to clarify, there is not audio out adjustment option in the audio&video menu, only the dolby digital on/off.
Thanks for the suggestions
von
Antwort hinzufügen
korellitor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,287
