Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
451 Fragen Alle anzeigen
"No AirPort Card Installed" — What can it be?
Hi there!
I've come across a MBP, that has a problem with an AirPort card. It says "No AirPort card installed". I've opened it up and found out that the card is actually damaged. I replaced the card with a new one, reinstalled the OS, but still the same problem. Strangely enough when I booted it up for the first time after replacement it could open the homepage (but only it!) while still saying that the card is not installed...
Could it be the WiFi antenna (one of its cables looks suspiciously twisted)? Or AirPort cable perhaps?
I would appreciate any help!
Thanks!
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
1 Antwort
Gewählte Lösung
Not only was your previous card damaged, so was the point where it connects to the logic board. You might be able to work around this by using a wireless dongle (USB). Only you can investigate and determine if repair or replacement of the logic board is economical (Soldering/repairing logic boards is not a beginner DIY project - it requires special tools, special solder and lots & lots of practice).
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
Punktzahl 2
Kommentare:
I believe if the antenna were the problem the card would be detected, show up in system profiler/information... what would not happen is finding a network to join.
von
Thanks a lot for the answer!
Well, that's too bad. But can it still be something else apart from the logic board? AirPort cable maybe?
I wouldn't replace the logic board. It's not worth it. But the replacement of the cable could be an option. Or is it?)
von
As I said use a USB dongle wireless card as a work around.
von
Antwort hinzufügen
diezmann wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 4,406
