Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1500 Fragen Alle anzeigen
Why is my display screen in black and white only?
I resently replaced my broken touch screen....since I put the phone back together I only get black and white images on my screen .... All buttons, apps and screen work perfectly... I just don't have any color.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 12
3 Kommentare
What a wacky problem!
von
It happened to me too. Its on my iphone 5c. When I push home 3x I get camera. Any suggestions?
von
I found that screen in settings. Thank you
von
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
Is the screen actually in black and white or could it be that its in reverse black on white contrast mode http://grab.by/Zgb
if it's the latter you can find the accessibility settings in your iPhone and turn it off.
War diese Antwort hilfreich?
Bewertung 9
4 Kommentare:
Stitchrobot - You're awesome!!
von
which one is the home button?
von
What is the home button?
von
Mine is doing this but I have a Google Pixel 2
von
Correct answer in my situation… Press the home button three times in succession and it will bring a menu option that says
"voice over"
"Invert colors"
"Zoom"...
You will most likely notice that the "zoom" option is checked… UNCheck this option and your screen will go back to colors!
Yea!!
Bewertung 6
5 Kommentare:
Awesome! Thank you so much as this has helped me!
von
Other experts could not fix problem, but you sure did, and many, many thanks
von
Thanks a bunch
von
Great brother,
It worked for me....thanks dude !!
von
Thanks I learned something New Today
von
tap your screen 3 times with three fingers. A menu will pop up. Touch choose filter and set to none.
Bewertung 4
1 Kommentar:
Omg thank you so much! Todd Ramsey ☺
von
looks like a cable issue to me (connector) - unless it's a broken screen.
But hey, colour is overrated !
Bewertung 3
I have LG Aristo that suddenly turned black/white
I tried everything, turning it off and back on, adjust settings, searched internet for help, etc...
Nothing seemed to work
)))UNTIL(((
I pulled down the screen at the top which give notifications and at the very top has signs of features that can be turned on and off by touch.
ie: WiFi strength, Sound, Bluetooth, Location, Rotation, Sync, Flashlight, Airplane Mode, Data, Battery Saver, Color Inversion and "COMFORT VIEW".
Clicked on 'COMFORT VIEW' and (((POOF))) everything went back to color.
Felt like I was in Wizard of OZ. LOL
Hope it helps fix your issue.
Have a GREAT Day!!!
Bewertung 1
1 Kommentar:
This solved the problem completely!
von
On the LG XPad 2, I pressed the Hot Key once and that put it back to color.
Bewertung 0
Antwort hinzufügen
Mytech wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 49,467
