Zum Hauptinhalt wechseln
Zweite Generation des CDMA iPad mit 16, 32 oder 64 GB Speicherkapazität und Dual Core A5 Prozessor. Modell Nummer A1397. Reparatur verlangt Feingefühl, Hitzezufuhr und Hebeln.
52 Fragen Alle anzeigen
dropped ipad, bent the alluminium case on the volume bottom
I've just dropped my ipad and the alluminium case bent on the volume button, i cant use the volume button and it stuck inside (volume square is frozen on the sceen). Is it possible to open the ipad and reshape the allumium case or is it too risky?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi Lou,
As you have probably noted, there is no screw to open the iPad 2 and in fact it make opening this iDevice much more complicate that an iPhone for example.
This is the reason why all iPad 2 guides are marked "Very difficult"!
I wouldn't say it is too risky, it depends on you, your skills and probably also your tools. If you want to make a good job you will have to use the good tools. Look at this iOpener at least!
  • If you decide to access the volume button hole from inside the rear case, the minimum require disassemble is the display. Look at this guide so you will have a better view on what you would have to do.
  • Once you will have the screen out, you will have a better view if further dis-assembly is required. Any further dis-assembly should be piece of cake after what you've done just before!
  • Also remember that you're gonna have to re-install the screen with new adhesive strips after that. (New adhesive strips available here.)
Let us know what is your decision, and good luck!
iPad 2 Adhesive Strips Bild
Produkt
$6.99
iOpener Bild
Produkt
iOpener
$19.99
iPad 2 CDMA LCD Bild
Anleitung
iPad 2 CDMA LCD austauschen
Schwierigkeitsgrad:
Sehr schwierig
40 minutes - 2 hours
iPad 2 CDMA Klebestreifen am Frontpanel Bild
Anleitung
iPad 2 CDMA Klebestreifen am Frontpanel ersetzen
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Bewertung 2
If the case is bent in the volume control area you can just use pliers to unbend the case. Be careful and use a cloth pad to avoid scaring the case. In my case (pun intended) the thin aluminum above the cutout part of the case was bent and Apple wanted almost as much as a new one to repair it.
Bewertung 0
Antwort hinzufügen
Lou wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 5,743
