Zum Hauptinhalt wechseln
Repair guides and support for top and front loading Whirlpool brand washers.
425 Fragen Alle anzeigen
Whirlpool washer model la5700xm will not spin. What can I do?
I have a Model LA 5700XM Whirlpool Washer.Washer does not spin in spin cycle even with the lid down.The wash tries to spin but will not. I checked the belt and it is not broken.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Does it drain properly? Do all the other programs work okay?
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
If the belt is slipping, the belt could have stretched from use. Adjusting the belt tensioner should solve your slipping problem, unless the belt has stretched so far that the tensioner no longer is putting pressure on the belt.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Motor Coupling
If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Motor Control Board
If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block
If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch
If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Tub Bearing
If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Transmission
If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Drive Motor
Bearing
Bewertung 3
I have occasionally had this problem, and unplugging and resetting the machine has worked so far. Always a good idea to restart anything with electronic controls as a first step.
Bewertung 1
1 Kommentar:
Agreed, always a first good step. But some need 5 minutes unplugged to reset.
von
I don't have an answer i manually moved the belt, but it seems to move slow.. i know this thread is years old.. but still am looking for some help.
I did realize the belt was loose, so i used a bar and serviced it like an old alternator and tightened it up.
now i'm going to try to unplug it for 5 minutes to reset it.
also did do a low water level wash run thrue with no cloths in it. seemed to be fine.
One issue was the belt lose and on the actual motor it wasn't catching the belt before i tightened it.
so in other words i caught the motor running but not the belt, like its sliding..
i did tighten it.. but then if it needs to spin or agitate the wash, i feel and think the motor may be going out..
so i looking at motor replacement or a ( new belt- which prolly isnt the case)
Thanks....
Bewertung 0
Antwort hinzufügen
freddie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 2,744
