Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
Frage geschlossen
My speaker hardly works, Help!
Last night someone thought it would be amusing to crack a raw egg on me and it got into my phone. Since then I can barley hear any sound coming out of the speaker. I've tried the toothbrush method and some other things and nothing has worked, in fact I think it might have made it worse. Is there anything I can do about it or do I have to get it replaced? I don't have any warranty on it
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Here is a good option for a new earpiece speaker, this company is in the US in San Francisco and are reputable, https://www.gounlock.com/details.php?ite..., 5.65 for the part and 11.00 for fedex 3 day shipping,,,before you order a new speaker, something you might also try, egg dries like cement, it probably has covered the steel screen over the speaker and little sound is getting through and the toothbrush trick isnt breaking it down, get a straight pin and scrape the screen with it, after lots of scraping clean it with an alcohol soaked toothbrush and hold the phone upside down while you scrub the screen so excess alcohol cant get into the speaker, let it dry for awhile upside down for 15 minutes befor you test to see if its fixed, good luck,
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
http://www.smartphone-parts.com/iPhone-4...
The part is only $3 here. I reccomend buying other parts too becuase it is $25 shipping. Its good for buying lots of parts at once on because this website has cheap high quality parts! You have to make an account to veiw prices though. But you need to buy the speaker and replace it, which is really easy
War diese Antwort hilfreich?
Bewertung 1
Here is a good option for a new earpiece speaker, this company is in the US in San Francisco and are reputable, https://www.gounlock.com/details.php?ite..., 5.65 for the part and 11.00 for fedex 3 day shipping,,,before you order a new speaker, something you might also try, egg dries like cement, it probably has covered the steel screen over the speaker and little sound is getting through and the toothbrush trick isnt breaking it down, get a straight pin and scrape the screen with it, after lots of scraping clean it with an alcohol soaked toothbrush and hold the phone upside down while you scrub the screen so excess alcohol cant get into the speaker, let it dry for awhile upside down for 15 minutes or so before you test to see if its fixed, good luck,
Bewertung 1
This is way late but for others using ifixit.com you need to remove the back of your iphone and remove the emi shield covering the speaker and check to make sure there is nothing in that area which is causing your inability to hear callers. If your able and willing you could replace the earpiece speaker without absorbing a huge cost.
Next time stay out of the Barley ( think you meant barely)
All the best
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 710
