Battery replaced, no earpiece sound
Didn't find an answer, so...
I replaced the battery according to instructions here. But when I got to removing ribbon cable 3 with white clip, the clip started coming apart anywhere i GENTLY lifted it (as instructed of course). Was as it the plastic was old an rotten. But the cable slipped out and I actually slipped it back in on reassembly.
But alas, no sound from the little speak at the top of the screen. Is there a possibility the ribbon cable does not correctly connect even though it appears to be slipped into place?
I can hear it if I put on bluetooth, turn on the speaker, or use an earphone in the jack.
Also did not see the screen adapt to the surrounding light but I was not really testing that.
And is there a way to fix that little white clip so it works properly?
Ist dies eine gute Frage?
