Zum Hauptinhalt wechseln
Eine sanitäre Vorrichtung zur Entsorgung menschlicher Abfälle. Kein Klempner notwendig! Eine Toilette zu reparieren ist unkomplizierter, als viele denken.
toilet bowl doesnt hold water
toilet bowl doesnt hold water, it flushes fine and wax ring doesnt leak. Tank fills and flushes but water doesnt stay in bowl
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 9
2 Kommentare
I installed a Kohler 1323429 toilet. Bowl is slowly losing water.
von
I installed a brand new toilet, but when the water is off you can hear water draining from the toilet, what is causing that, the toilet,tub,sink,is all one drain
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
tom hogg, of course, this may be a difficult question to answer since we do not know the make and model of your toilet ;-) Remember that the water stays at a given level because of the u-bend, which is called a trap, within the porcelain of your toilet. The shape of the bend will determine the height of the water level. So, it is possible that that there is a crack in the trap of the toilet its self and the water is slowly running down the drain (lucky you ). The other, and actually more common issue can be a clogged or improperly installed vent. One way you can check for a plugged vent by flushing the toilet, When the toilet then fills and the tank shuts off the water to the toilet, turn on the hot and cold water on the closest fixture to the toilet, most likely your sink or the tub. If the water level moves in the toilet you have a clogged vent. The change in the level will happen within minutes. Check the vent where it sticks up through the roof and look for obstructions. You can use a snake to snake out the vent stack or flush it with a garden hose (could be messy). The other problem can be a partially clogged downstream drain line. That could siphon the water out of the toilet. give your system a good cleaning with a snake and see what happens. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 11
4 Kommentare:
If there is a partial clog in the vent pipe, Why would running the water nearest the toilet impact the water level in the toilet?
von
@tryinghard syphoning effect from the other drain if it connects to the same vent stack. It would sypon it out as the other drain empties to equal the pressure.
von
Much appreciated.
von
@oldturkey03 good answer. It does seem to be more of a venting issue as the water moves in the bowl like it is shipboard with a rocking boat. Thank you for the answer.
von
You are screwed , it cannot be fixed unless you replace your entire plumbing system pipes , fixtures, valves, water heater , washing machine , meter , spigots and line from meter to house.
Bewertung 1
1 Kommentar:
Your troll game is weak af, sir 😂
von
Actually it had to do with the fact we had a 2-hour power outage and the vent must have been affected.
I called a plumber, he flushed it about 4 more times, and voila, the water is now in there and stays.
Who knows why it wouldn't stay at first?
Bewertung 0
Antwort hinzufügen
tom hogg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 25
Letzte 7 Tage: 216
Letzte 30 Tage: 1,063
Insgesamt: 312,962
