How do I reconnect my ribbon cable to its connector?
While changing the battery on my Garmin Nuvi 680, the most internal cable disconnected from its connector and I don't know if the connector lifts vertically, slides out or is soldered to the motherboard. Beyond that, I don't know how to reattach the cable.
thanks
Ist dies eine gute Frage?
3 Kommentare
Scott Hoffman, take a look at this guide and give us the step that shows us the cable. Most of the connectors have a clip you have to lift up.
von oldturkey03
My Garmin RV 660 LMT has a ribbon that came off when I opened the case. I doesn't have a clip or fastener that I can see. The ribbon itself is about 5/8" wide. Where it connects there's nothing but a very small piece of plastic material; long and narrow; but it doesn't snap into anything just kind of lays there. How do I connect this ribbon back onto the board?
10/28/20 iblopaka2@gmail.com
von Robert Tafolla
Ribon came out,, cover came off. I don't see where the ribbon is supposed to sit before you press it down. Does it curve and sit in inside (gold )area then come to flat pins OR does it lay flat and be pressed in to pins (silver) that ) lay flat on back of gps?
von Cindy napoli
