Zum Hauptinhalt wechseln
Die dritte Version von Canons Kompaktkamera-Design mit Superzoom-Objektiv. Ursprünglich veröffentlicht im Februar 2006.
getting message to change the batteries after doing so
I used the camera less than a month ago. Now getting the message to change the batteries and have done so with NEW ones. Powers up ok, but after trying to take pic, gives the change batteries message. Have cleaned the "terminals" on the battery compartment door and have taken out memory card and reinserted.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
4 Kommentare
Have you tried a different set of new batteries? What type of batteries are you using?
von
Duracell - and I'll try another set of new ones and keep my fingers crossed!
von
nonees...... can you please tell me if it worked; I tried it on mine but no luck.
Thank you.
von
I tried this one on mine but still didn't work, is there any other solutions to this issue?
von
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
nonees, the issue here could be your battery compartment door. Make sure that it makes good contact as well as the bottom contacts. If it does, and everything else checks out, replace the RTC ( 'date/time') battery. Even if your regular batteries are fully charged and are making good contact etc, if your RTC battery is discharged, it won't make any difference, and you can get this error message. That battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open). It is a coin type battery CR1220 Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 4
7 Kommentare:
OldTurkey03 - thank you for the clue about the RTC battery! I'll have to pick one up at the store but I bet you have solved the problem! I'll be sure to let you know - thanks again! nonee_s@yahoo.com
von
Cleaning off the RTC battery also fixed it!!!
von
I just replaced the RTC battery, and it still does the original problem. Any other suggestions?
von
AyoItsAbby what is your original problem? What make and model camera? What else have you tried?
von
12 years later.. this worked for me. Thank you so much
von
2 weitere Kommentare anzeigen
Hi not sure if it would help, try taking the batteries out from the camera and leave it out of camera for a few hrs (2 maybe?). While waiting, try to power on the camera the normal way to discharge any possible remaining power. Then, reinsert the batteries back into the camera and power on to see if it helps.
Some machines somehow needs a full discharge to 'help erase' issues it has and encountered and to restart afresh.. Not sure the terms are correct but thts how i learnt over the years.
Hope the above helps! Good Luck! :)
Bewertung 0
2 Kommentare:
Tried your suggestion, but same message - change the batteries..... may have to send to Canon to fix
von
can someone send a picture of where the rtc battery is on the camera
von
Canon PowerShot SX220 HS in many cases is displaying the error message "Change the battery pack" although the battery is fully charged. One solution to this problem is to add some element (paper) between the battery and the battery door to ensure better electric contact.
http://dubaibuildingsforsale.com
Bewertung 0
1 Kommentar:
Don't understand how can putting paper between the battery and the battery door imorive the electric contact?
von
Would also suggest testing/ replacing the memory backup battery which is located under a flip out cover on top left side of SX120IS. It is a CR1220 button cell and generates a replace the batteries error even with fresh batteries. If you don’t have a battery tester just pull out this battery and try starting up the camera with fresh AA batteries. If the CR1220 is bad the camera will now start up in picture taking mode.
This seems to be a common error message on a number of older Canon PowerShot cameras especially ones that use AA batteries so worth checking to see if the memory backup is bad and you get this error after putting in a fresh battery.
Bewertung 0
If you don’t care about the time/date staying between power cycles I was able to just remove the little cr 1220 battery entirely to get rid of the error.
Bewertung 0
Canon PowerShot A630. I removed the Memory card and reformatted it. It seemed to fix the “change the batteries” problem for now…
Bewertung 0
Antwort hinzufügen
nonees wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 96
Insgesamt: 31,567
