Zum Hauptinhalt wechseln
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
21 Fragen Alle anzeigen
Frage geschlossen
Can you cut one set of wires?
My floor lamp has five arms resulting in 10 wires, can I cut one set of wires and cap (one arm has faulty base)?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes but you must cap/insulate each end of the pair you cut.
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
Bewertung 2
I can confirm previous answer.Its not necessary but if possible also is good to check for grounding,or short circuit..
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 254
