How do you install new RAM boards
My computer runs fine but the RAM usage really stinks and I don't know how to install new ones
Ist dies eine gute Frage?
Brandon, it is not to difficult. "
1 Ground yourself by touching one of the metal connectors on the back of the computer.
2 Turn the computer over, loosen the captive screws on the memory module cover, and then remove the memory module cover.
3 If you are replacing a memory module, remove the existing module:
a Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
b Remove the module from the connector.
4 Ground yourself and install the new memory module:
a Align the notch in the module edge connector with the tab in the connector slot.
b Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
NOTICE: If you need to install memory modules in two connectors, install a memory module in the connector labeled “DIMMA” before you install a module in the connector labeled “DIMMB.” Insert memory modules at a 45-degree angle to avoid damaging the connector.
NOTE: If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
5 Replace the memory module cover.
download the manual from here. Page 79 and on are the ones you want. Hope this helps, good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 929
