Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
What do I use to "reglue" my wifi antenna?
A while back, I broke my IPod 4g screen, so recently I bought a new screen and replaced it. Worked great. However, in the process, I unattached and unplugged my Wifi antenna...It was held down with some sort of..adhesive substance. I plugged the antenna back in but now my Wifi goes in and out. If I hold it down with tweezers, my internet connection is fine, but once I let go, I slowly start to loose connection. I figure that I need some sort of glue to keep it held down, but I can't find exactly what I should use... Anyone know? Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I would use some very very thin electrical tape, or you could find an equivalent to it. Basically the reason your wifi goes in and out is that the iPod uses the outer metal case to strengthen the antenna, hence when you press it against the case it works fine. All you need to do is find something that is NOT conductive, and is small and adhesive enough to keep it secured.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Would liquid electrical tape work? I was looking at this: http://www.amazon.com/Star-Brite-1-Ounce...
von
Keila Black, that stuff might just work. It does fit all the criteria needed, just try not to make a mess with it :-)
von
lol. I imagine myself making more of a mess with physical tape..like accidentally ripping the WiFi antenna cause I taped it down wrong or something. XD but anyways, thanks for the help!
von
Use Double Sided Tape it will work just fine. Put it between the antenna and the white plastic, not between the antenna and the front panel.
Use the transparent tape.
Do not use the black thick tape, or you will be not able to close the front panel.
Bewertung 1
Don't bother gluing it or taping it. The way the screen fits there is almost zero "wiggle" room for extra adhesives or tapes. You are risking having the screen sit unevenly and getting possible white pressure points on the screen and worst case scenario you could damage the LCD. Just sit it in the right place and install the screen. I have never had any issues doing it this way, just make sure the antenna is completely connected. You don't want to have to re-open it to fix.
Bewertung 0
Antwort hinzufügen
Keila Black wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 767
