Zum Hauptinhalt wechseln
Dell Inspiron 1420 14.1" laptop, released in June 2008. Identified as the 1420 on the bezel above the keyboard, available in 8 different colors.
some keys not working
for quite some time some keys on the keyboard not working.the repairing shop says i have to change the entire keyboard.can i repair it myself?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
suddenly my keyboard all letters r not working
War diese Antwort hilfreich?
Bewertung 1
uc123, you absolutely can do this yourself. Download the service manual for your computer from here, (not knowing where you are located) you could get a new keyboard from here, and replace it. Hope this helps, good luck.
Bewertung 0
Replacing the keyboard would be the last option, all you need to is to arrange some isopropyal alcohol or use a c2c carbon clean solution then try to inject one drop via syringe, make sure to not increase the quantity more then one drop and let the each key to be dry for like half hour or alternately you can use a hair dryer a 1 feet distance this can might fix your non working keys.
Bewertung 0
Antwort hinzufügen
uc123 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 39
Insgesamt: 1,446
