Fuel Door - Trunk Releases Sporadic
Cadillac '96 2dr LTD
My fuel door and trunk lid are requiring about 20 attempts to open with both the remote and interior buttons. This began all of a sudden. Anybody know a fix?
Ist dies eine gute Frage?
My thoughts on this: 1st: how long has it been since you changed your battery in your remote? I find that mine last about a year to two years before having to replace. 2nd: if you do not drive the car much you may have got the lube on the actuators hardened from lack of movement. Re-lubing or greasing them may do wonders. 3rd: how is the charge on the car battery? you may want to put a charger on it to bring it all the way up and see how things are before spending any real time on the problem.
When you use the car switch to open fuel or trunk do you get a click at the unit your trying to open, or is there just no sound except every once in a while. Same question with the remote.
Let us know and we can see if something else comes to mind.
good luck
War diese Antwort hilfreich?
Car battery is only a month old. Remote battery is 6 months old. This would not explain the interior button not working. I don't remember ever hearing a sound with either except the sound made when it releases. The car door seems to work fine with the remote. Do you know if these things are electronic or vacuum operated?
Questions on the batteries is to establish their health. The releases on the GM's are usually electrical or mechanical. I think yours are both electrical since the engine vacuum would bleed off over a period of time making that type not useful if left for a day or so. I would take a look at the actuator at both the trunk and gas door themselves given the batteries sound like they should be fine. Maybe just manually moving them a few times could help them be more reliable.
Looks like the main problem was that I had not been driving it enough.
Hay Ken, thanks for the input. the key fob opens the trunk just fine and in my vette ,the click from the actuators for both the trunk and the fuel lid are very prevalent and obvious as to what they are and what hatch they activate the release for. how ever the push button switch on the dash is the one in question.it suddenly stopped functioning! the only thing i have done recently that relates to the elec. sys is the fuse link under the battery box between the starter and the battery. is that something that could effect the functions in question? and just FYI i checked the fuses under the passenger side floor pannel and they check out good.
I would look into replacing the relay that moves the electrical signal to the actuators. It may be located in the electrical 'block' under the dash near the brake pedal by all the fuses where all the older GM cars had it, or some probing around the internet leads me to believe there are three fuse boxes located under the hood.
Remember, the switches and remote operate on small amounts of amperage, and they only actuate another switch or relay to get the real power over to the locks. Sounds to me like yours is sticking.
I was able to find a GM door lock relay diagram and there appears to be two relays controlling the actuator. One open, one close.
Here is one of the parts for about 5 bucks
hi,while starting my 2002 Eldorodo,i have'd resently experenced the fuel door & the trunk door openning at the same time. what can be causing that. Please Help.. Thanks
This is a different issue. Please start a new question. Thanks
I do have an answer.
hi, I have a 02, Eldorado. resently the Fuel Door & The Truck have been openning when starting the car. Never experenced this problem before. Can it be a easy fix? thanks for your Help!!!!!
I have a 1999 DeElegance and the problem of the trunk and fuel door opening was tide to the alternator going bad which also drained the battery replace both (they recommend you replace the battery if the alternator goes bad) and never had the problem again. Piece of advice if you replace the alternator and not the battery in about 6months to a year you will be replacing both anyway had to learn the had way hope this helps
How do u open gas cap with the string in trunk I pulled it out
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 7,989
