Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für dein Apple Wireless Keyboard. Verbinde und kontrolliere deinen Apple Computer kabellos.
Factory reset or re-install firmware?
The recent firmware 1.1 update appeared to install correctly.
BUT, since the update the keyboard does not work properly - random ' characters and shift key not shifting case.
Attempts to reinstall 1.1 update or 1.0 updates are blocked by - "Your keyboard is already updated!"
Any secret key combo to reset the firmware or force a new (or old) update?
Or do I now have a useless keyboard?
Mac Mini. OS X 10.6.3 aluminum bluetooth keyboard (2007 3 battery)
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
What computer and OS are you using? Ralph
von
OS X 10.6.3 - it was the automatic update that included the keyboard firmware update that caused my problem.
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
Here is the Apple paperwork for the update giving you problems. It appears to list steps to be taken after install. Maybe this will help you. Ralph
http://support.apple.com/kb/HT4010
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks for the suggestion.
Yes, I did that immediately. It reports the correct version number for the new firmware having been installed.
Of course, being very user friendly it reports the version in hex, but I know how to convert 0x141 to 321.
I am quite surprised Apple expects their users to do this. I have gained a new respect for the average Mac user.
von
did you try the troubleshooting from here ?
maybe this would help to get mor information about the non (or wrong) functioning keys
Bewertung 1
1 Kommentar:
Thanks markus. It sees the same thing as any app. The keyboard is sending bad info.
I borrowed another keyboard and it works fine.
The problem is definitely in the keyboard and requires reloading of the firmware, which apparently loaded badly (despite giving no errors).
von
I have 2 Aluminum Apple keyboards ruined from an update of my macmini. pretty upsetting. apple is the new Microsoft. Apple updates used to be stable now they are shyt. one has non working keys while pressing shift another has a repeating number on startup for no reason.
Bewertung 0
This works...
resetting BT keyboard
Basically, you need to hold the power button the ENTIRE time you pair.
Try and see if it works.
Bewertung 0
The A1016 Mac wireless BT keyboard WILL work with Mavricks with no additional software, I dug out my old keyboard and put new batteries in and it attempted to paired up, but I had to remove all the other devices and then pair. After that you can pair up your other devices. I had to have patience, but it got there
Bewertung 0
1 Kommentar:
how did you remove all the old info from the A1016? I just found one that works perfect but when i try and pair with it, it asks for the keyboards pin number... and it say's the old owners name. i bought it from an electronic recycling store, so no way to contact original owner
von
Antwort hinzufügen
Peter Jennings wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 24
Insgesamt: 54,823
