Zum Hauptinhalt wechseln
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465 Fragen Alle anzeigen
Blu-Ray Disc Wont take disc?
I am working on my ps3 i followed the "Installing PlayStation 3 Slim Blu-ray Disc Drive" guide to take it down and i looked up some other videos to take apart the blu-ray drive. I need help on fixing the Blu-ray drive. i can take it apart but i need help knowing what to do to fix the player. right now the player will not suck in the disc but i can put a disc in manually but nothing will happen. the only thing disc will do is eject. Please help me.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
If you know how to take apart the drive, remove the metal shield and the second layer. Once that is removed you should see a gear mechanism in the bottom right corner. Look at it and make sure it is engaged to the sprockets. If not, there is a release with a spring on the left side that you will have to turn to release the black platform. Now re-engage the drive mechanism by pushing it against the white sprocket, while turning the sprocket. Once it's back together reassemble and test.
I've found this to be one of the more common issues for the problem you described.
Good luck, and let us know how it goes...
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
im a girl with no help from any guys can you please walk me through the process i already have the metal shield and the second layer off
von
The above answer worked for me when all hope was lost thank you!
Bewertung 0
1 Kommentar:
could you help me with this i already have the shield and the second layer off
von
I took my ps3 apart to fix it and its still not reading disc and its making ejection noise
Bewertung 0
Antwort hinzufügen
Theodore Osbourne wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 8,200
