Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
No one can hear me through the microphone, Only through speakerphone?
I have an iphone 4. I recently replaced the back glass from cracked after dropping it. It worked fine. Then 1 week later a baseball hit it at a baseball game (inside a otterbox case) Phone backglass cracked again at rear camera area. Now no one can hear me talk in a call unless I am on speakerphone.
I am confused on what mic I may need to replace. The top or bottom. Or if its could be something other than a mic that is the issue.
Ist dies eine gute Frage?
Bewertung 8
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
I have 3 solutions
this works on Iphone 4
i have tested all 3 of them, and have had success with all 3 solutions..
The Problem:
Iphone 4 lower microphone stops working.
recording video and memos works fine, but people cant hear me during calls.
just to clear things up for everyone...
when using video recording, memos or anthing else that can record your voice, the iphone is using the TOP MICROPHONE.
when calling/getting calls the iphone will be using the LOWER MICROPHONE.
When you put it on "Speaker" then the phone will use both.
Solution 1:
Change the Dock Connector
if that wont work... then....
Solution 2:
Click on this link, and follow the instructions, on how to fix the Compiler Chip.
iPhone audio problem: fixing an audio compiler chip fault
sounds and looks wierd...., but yes it works....
done it with multiple phones so far...
if solution 1 does not fix the problem, then solution 2 should help allot.....
should the problem still persist, then you might have a problem with your Home button.
See Solution 3 for more info
Solution 3:
Change the Home button.
this last solution was the problem solver for me... i had 7 dock connecters, new and from other broken phones i tested with.
in the end, the home button just gave up when i was swapping around, then i just replaced it, and Voila.... my microphone was working again, and my home button was working too :D
i cant really explain what really happend, but its my 4th iphone i have had these problems with, and all has been repaired with these 3 simple solutions...
i really hope it can help alot of people in here, with issues with iphone 4 microphones not working
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Works great thank you for sharing, been searching for hours!!!
von
I tried All Above Solution But Mic Is Still Off
von
the bottom mic is the one used for all calls so try changing that one. The top mic is for noise cancellation only.
Bewertung 1
Say chicken noodle soup with soda on the side twice
Bewertung 1
Antwort hinzufügen
Stacey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 74,078
