Do you have a Windows 7 Installation Disk? If you do not this is going to be a difficult fix.
What you need to do:
1) Boot using a Windows 7 Installation Disk (If you need help with that, let me know)
2) Right after the BIOS Splash screen, start hitting "F8" repeatedly... like a lot.
3) You will be prompted to a menu, choose "Repair your Computer"
4) If it asks for which installation choose, Windows 7
5) After the automatic System Repair is finished, it will ask you what to do next.
6) Choose "View Advanced Diagnostic Tools" (Or something like that, I am doing this from memory lol)
7) In the next menu, choose Command Prompt.
8) Once there you need to type this exactly, without quotations, also each "_" represents a space.
- "sfc_/scannow_/offbootdir=C:\_/offwindir=C:\windows"
This scan may take quite awhile. What it does is scan all of your essential windows files and components, and will automatically repair them. You will get a message at the end telling you if it made a repair, or if it did not find anything.
9) Next you are going to run CHKDSK. To do this type: "chkdsk C: /f /r" This will run Checkdisk and it will also scan, and repair any Windows files.
10) Restart your computer after everything is done. Generally this is an hour to 2 hour process.
I hope this helps.
Nate
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
Have you tried to boot into Safemode?
von oldturkey03
i click safe mode the screen pops up asking which os do i want to choose i dont choose anything and right away it gives me the same error message as before
von Phantomx
Did the OS get updated from XP to Win7?
von oldturkey03
