Zum Hauptinhalt wechseln
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Fragen Alle anzeigen
Screen comes on but does not light up.
I have a PowerBook G4 Aluminum 17" 1-1.67 GHz and it was working fine. All of the sudden the screen comes on but does not light up. I was told that it was probably an inverter board, so I bought a replacement. After a 6 hour tear down and reconstruction it does the same thing. All wires are connected and tight. Any help or ideas would be appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It's a widespread myth that the inverter is the problem in these situations (spread mostly by people who have never done a laptop repair), and 99% of the time it's actually the inverter cable, or the screen itself. With MacBooks and PowerBooks it typically ends up being the screen, however you might want to replace the inverter cable first, since it's a relatively cheap part and there is a chance it's the culprit.
Also, before you start spending money on parts, you'll want to connect the laptop to an external display. If that works fine, you'll have ruled out the logic board as part of the problem, whereas if the external display doesn't work, it's possible you've got a video chip issue.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Agreed +
von
Antwort hinzufügen
mrclark wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 723
