Zum Hauptinhalt wechseln
Anleitungen zum Reparieren oder zur Fehlerbehebung von Zubehör für die zahlreichen Spielkonsolen von Nintendo.
Screw driver to disassemble the wii nunchuk
Does anybody know if the driver for the diy 54 bit driver kit will fit to remove the tr-wing screw on the wii nunchuk?
If not is there a recommended driver I can purchase from ifixit?
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hello
The tri-wing screws used in the Nintendo Wii are Y0. This bit is in the 54 bit driver kit, but you can buy this screwdriver alone too.
Here are the links:
54 Bit Driver kit: http://www.ifixit.com/Tools/54-Bit-Drive...
Y0 screwdriver: Tri-point Y0 Screwdriver
Similar to a Phillips, but with 3 blades. Precision fixed blade screwdriver engineered by iFixit. Bild
Produkt
$5.49
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
excellent. I did end up getting the 54 bit driver kit however i was worried that on the wii nunchuk it would be too narrow for the driver from the kit to fit. Can anyone confirm this? Thanks!
von
In case anyone else is looking for this answer. The Y0 in the 54 bit driver kit is too wide. The tri-point Y0 standalone screwdriver however worked perfectly.
Thanks.
von
There a guide here (Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly) which says "Tri-point #1". Is this a mistake?
von
Antwort hinzufügen
Jase1516 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 58
Insgesamt: 6,272
