Zum Hauptinhalt wechseln
Model number TF700T released in July 2012. The Asus Transformer Pad Infinity is a Wi-Fi and Bluetooth capable tablet with a 10.1 inch screen and 8MP camera.
8 Fragen Alle anzeigen
How to Replace ASUS Tranformer infinity Digitizer TF700
Hi Everyone,
I smashed the digitizer screen on my TF700, i found a replacement but on disassembly it appears that the front bezel is irriversibly bonded to the digitizer, does anyone know where to buy the bezel i have searched online but can find nothing. Do you think asus would sell the part directly? I dont see any other way to put the tablet back together without the bezel.
Thanks in advance
Chris
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I had the same issue - the bezel is extremely thin / lightweight and is bonded to the screen glass with double sided tape. I found I could remove all the old glass and tape with v. careful use of a hot air gun and and a knife blade. BE V CAREFUL WITH THE HEAT - the bezel deforms pretty easily. I then used some double sided tape to restick my new glass and hey - presto... HTH
War diese Antwort hilfreich?
Bewertung 0
I used a hairdryer and a stanley knife to separate all the bits from the plastic, I then used White Spirit to clean the glue off the plastic and Double sided tape to bond it to the new one. I later plugged the lcd cable into the screen while the machine was on and melted the connector.... but that's a different story. Make sure you don't do that bit.
Bewertung 0
Antwort hinzufügen
Christopher Contino wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 3,207
