Zum Hauptinhalt wechseln
THINKPAD T520: Top Tier Performance and Portability.
17 Fragen Alle anzeigen
Frage geschlossen
Why does my laptop keep on beeping at me?
A few months after i got my laptop something weird was starting. Everytime I kept on trying to turn on my laptop it kept on beeping three times at me. It also stops the screen from turning on, can someone please help me, I need to fix it!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Katie Louise, you should tell us more about the exact beeps.One long and two short beeps, and a blank or unreadable LCD are indicative of either a bad mother board, a bad LCD, or bad memory modules. I would start by attaching an external monitor and see if it makes a difference. After that, pull the memory modules and reinsert one module at a time. Make sure that it is properly seated. If none of this works, you probably have a bad mother board. Hoe this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
The first beep is long, and then nothing happens for 2seconds than the other two go one after the other. I have a bad mother board, i tried all your steps but none of them worked :( thanks for trying to help anyway :)
von
Thank you for accepting my answer. sorry to hear about your motherboard. May be you could still be covered under warranty?
von
Diese Antwort bezog sich ursprünglich auf eine andere Frage.
3 BEEPS -- PAUSE 3 BEEPS ETC... USUALLY EQUALS MEMORY UNSEATED OR MISSING. Reseat the memory in it's sockets
Bewertung 0
My computer is beeping. There is usually 4 quick beats, then over 10 slow beats, then just random. What could the problem be?
Bewertung 0
2 Kommentare:
sonya what make and model is your computer?
von
Hi, it is an Acer aspire 5732Z
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 5,372
