Zum Hauptinhalt wechseln
The Samsung Galaxy Ace is a low-end, slate-format Android device released by Samsung on February 2011. Identifiable by model numbers GT-S5830(i, B, C, L).
31 Fragen Alle anzeigen
How can I replace my charging port
inside my charging port is snapped but the main port is still fixed to my phone i would like to know how to replace it as ive bought 2 new charging ports but dont know how to fit them
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
mark, follow this teardown, you should get to the logic board. There you can replace the port itself. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
sometimes the USB jack may not be working properly, but you can change it of course,you will need to solder it to the board since it is not a flat one
Bewertung 1
1 Kommentar:
ok thank you fo r your help
von
Antwort hinzufügen
mark wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 7,247
