Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Frage geschlossen
iPhone 4S - No Service but carriers show?
Guys,
I've had problems fixing a 4S a friend gave me. I'd love to get it back to working order as cosmetically it is brand new, and everything except the signal works great.
It was dropped, I repaired the screen, camera and swapped the battery. Its was locked to (3) UK, I got it unlocked with a code.
It is now just stuck on 'searching' or 'no service'.
When I goto Settings > Carrier, I can press 'manual' and the services show, which makes me think that there isn't any major problem. However, even if I select the network, it still shows no service.
If somebody can help me out it'd be much appreciated, be happy to throw them some paypal their way.
EDIT - Ive just taken it into town and it came up with FULL SIGNAL for around 2 mins, then went back to no signal. Does anybody know what the problem is?
Many Thanks!
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Ive tried setting the date and time. They are set correctly, set to automatic. Is that right? Or is there a trick to it? Any other ideas people?
von
Einen Kommentar hinzufügen
7 Antworten
Hilfreichste Antwort
make sure date and time and set corretly
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks, but the date trick did not work on this one. I have added an EDIT into my post on what happened today. Any other ideas? Thanks
von
Just had the same problem on my 4s now for the last week. Just reset network settings and problem solved ... Mobile signal returned. I had to set up my wifi password again but otherwise all good.
Settings>General>Reset>Reset Network Settings
Bewertung 1
got the same problem with my 4s.
just "searching" or "no Service"
Carriers are shown when switched to manual... so i guess it finds the network but couldn´t or won´t log in... don´t know.
are there any new suggestions for this problem?
it runs with ios7
Bewertung 0
Be nice if we could get some answer that would help us mine doing the same thingy an it brand new pretty much !
Bewertung 0
Weird stuff guys. Usually I get the opposite problem, with customers phones
Bewertung 0
Does anybody has the answer? i'm having the same problem manual carrier selection shows list of available carriers i tick my simcard carrier done but no service and not even a single bar of signal, soon it shows me my network lost..help please
Bewertung 0
have you tried changing the speaker at the bottom as the antenna is connected to it , or make sure the cable is seated properly could possible be that ,
hope it helps
Bewertung 0
8 Kommentare:
not yet but i'll try it now, thank you i will keep you updated
von
i have the same problem on iphone 5s im just going to changed the antenna now , ive searched this so many times , and no soloution
von
Have you guys checked IMEI number to see if it is blocked?
von
i have checked the cellular antenna cable is seated properly, imei is clean also, i cannot even dial emergency number, restore normal dfu and recovery still i cannot get even one signal
von
ive done the exact same changed antenna , check imei , i get ee signal , 3g/4g but cant dial out etc , this a joke , i have a apple brick
von
3 weitere Kommentare anzeigen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 4,488
