Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
iPhone 5 power button and home button doesn´t work + no service
Hi, I just changed the flex for the power button in my iPhone 5 from another iphone 5, but when i changed it, It wouldn´t work. After the change, the home-button didn´t work either and it said i had "no service".
I have just spend hours trying to work this out, i have disassembly it many times and tried to find the failture, but i still do not find it!..
Please help me..
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
I have same problem, any one please?
War diese Antwort hilfreich?
Bewertung 0
when the phone is open you can connect the two little gold springs at the bottom with a screwdriver, to make the phone think the home button is pressed. does that still work?
if so there must be something wrong with the home button flex cable.
if not, clean the contacts of the lighting connector or replace it
keep us posted
about the reception? are you sure all cables are connected? be sure the two back thin ones are seated properly, also try cleaning them
Bewertung 0
I'm going to refer you to this : Home button + Power button doens't work after display replacement?
apparently there are 3 tiny chips on the left side of the gsm card reader that create this problem if they are damaged. You'll probably need to go to a repair shop to get them replaced.
Bewertung 0
"No service" or "Searching" is what I always see after repairing a phone up to a level where the battery was disconnected.
It's something with the physical memory I guess, but anyway, you have to connect your phone to a wifi network or itunes, wait a bit for the clock to auto adjust and than switch flight mode on & wait 10s & off. Sometimes you get a popup "server identity not checked" or smth like that. Just press proceed.
This should fix the "no service" issue.
The homebutton: use a bit of sandpaper (P500) to clean the two copper tabs on the phone. Make sure they stand upwards enough to touch to two copper dots on the homebutton ribbon.
Power button: Since it's bracket has a hinge, it's very tricky to tear the ribbon cable when installing...
Bewertung 0
Antwort hinzufügen
Torgeir vikane wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 3,615
