What are ohm readings for 2001 Hyundai Santa Fe coil pack testing?
2001 santa fe Hyundai 2.4 ltr. 5spd manual transmission
Ist dies eine gute Frage?
luana, try this :-)" 1. Measurement of the primary coil resistance. Connect the negative (-) terminal of a 3V power supply to terminal 2 of the power transistor; then check whether there is continuity between terminal 3 and terminal 2 when terminal 1 and the positive (+) terminal are connected and disconnected.
Replace the power transistor if there is malfunction
1. Measurement of the secondary coil resistance.
Measure the resistance between the high-voltage terminals of the ignition coil.
Standard Value:
20+/- 15%(Kohm)
Hope this helps, good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 2,052
