Zum Hauptinhalt wechseln
Der PowerMac G5 ist ein Desktop-Computer, der erstmals 2003 von Apple Corporation produziert wurde. Diese Anleitung zeigt dir, wie du den PowerMac G5 (Modellnummer A1047, EMC: 2061, von 2004) reparieren kannst.
197 Fragen Alle anzeigen
Where is "Memory Heatsink" placed?
I cant find where the sensor 4 "Memory Heatsink" are placed on a mac G5 / late 2004 / 2,5 GHZ.
WHERE CAN I FIND SOFTWHARE 4 CALIBRATE THE SENSOR, its showing 20 DEGR TO HIGH temperature.
IF SENSOR Is ON some cind of cabel, mabee it has been placed wrong, under the warmer part, near the processor.
FAN NOISE - IS THE COMMON REASON 4 ASK.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You need to find a copy of the AHT for your computer to calibrate it and restore the fans to normal speed. I am including the link from Apple for the PowerMac G5. From this link you can download the manual which should answer your questions about the sensors. Good luck from a fellow G5 owner, Ralph
http://www.apple.com/support/powermac/
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
What is "AHT" - I am swedish - so i dont understand what its mean.? If you know where to find the sensor - is it any chanse that the answere could be put in this chat?
Thanks 4 the answere, anyway.
von
AHT - U mean Apple Hardware Test = problem - I dont have the original CD. And I cant find any AHT for G5 to download (apple have it for some other models),
But I have Sotfware "Hardware Monitor" - and through that i can see where the problem is = Memory Heatsink = showing to high temperature.
I NEED to know - where to find the "Memory Heatsink Sensor" - where is it placed ? Is it directly on motherboard, or is it throug som cable? If so, perhaps some one before me has moved it to wrong (warmer) place ?
von
From what I can tell the sensor is built in to the heatsink/processor package. This package can't be opened without destroying the processor. If you have not done so please download the manual as it gives a great deal of info (text and photos) to help you maintain the system. Ralph
von
Antwort hinzufügen
Goran wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,748
