Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2201 Fragen Alle anzeigen
Broken Battery Connection on logic board.
Ok so this person asked me to fix their iphone 4s because it would only work when plugging it into the computer. However I later discovered that the connection from the FPC battery connector onto the logic board had been broken off and one of the connections is completely broken off and I can take it right off the board. I was wondering if anyone had the best way to approach this problem. I have some soldering background and if that is needed I would be able to do so.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
any chance you can post an image of the damaged board with your question? that way we can see what you see:-) Use this guide Adding images to an existing answer to add images.
von
Hi sorry for the late response and I have added the photos. It is in pretty bad shape and I think one of the connections is missing.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Ralph, sure looks like it has seen better days. I would try and change the battery ways. check the attached image for the routing. this will of course only work if all your other components are still functioning. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
all this is not neccecery !! i had same problem but just put some pressure on it vith a sim card i cut out and put on top,then bit the phone assambled it put pressure on the connections,i actualy am not sure they were ever solded,benefits is also that with good conection now it last power more days!!!!
Bewertung 0
Antwort hinzufügen
Ralph wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 997
