Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2397 Fragen Alle anzeigen
iPhone doesn´t charge even after repair it
My iphone 4 was charging very slow (10% by hour) and it didn't detect that its plugged, so I thought "May be the battery was dead", so I replace it and it didn't change. After that I decided that the dock connector is the problem, so i replaced it but the problem persist.
Maybe something on the logic board is damaged?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
3 Kommentare
Like Vincent Monteil says, try a different cable as well as an AC adapter and see if that makes a difference.
von
I've tried with lots of cables even with a 30-pin to RCA and it doesn't stream video or audio
von
Have you checked the charging coil and components?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi jim !
In fact, people often think that the problem comes from a dysfunctional iPhone part. Actually, the problem could absolutely be your connexion cable or AC Adapter ! Do you use an official one ? Is it old ? I know that it can seem to be nothing but even if they are more expensive, you shall prefer using official new one. Your iPhone is mabe ok !
Let us know how it goes,
Hoping to have helped you,
Vincent
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
jimenezser wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 203
