adapter tip has broken off in my computer
Adapter tip is inside my computer and I can't get it out. It is a aluminum 15 inch
Ist dies eine gute Frage?
The part it's in is called the DC IN port. Once this is removed the center bracket on the back of the unit can sometimes be pulled slightly out and the tip removed. If this cannot be done, it's a fairly simple procedure to replace it. We do need to know exactly which machine you have to direct you to the correct part and instructions for replacing it.
War diese Antwort hilfreich?
Was it a tight fit, or was it somewhat loose? You might be able to use a powerful magnet to pull it out. Of course, make sure you keep the magnet away from where the harddrive is located. I imagine it is in the center somewhere, but it's hard to tell since we don't know your exact specs.
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,045
1 Kommentar
which specific one do you have? Titanium or Aluminum?
von rab777hp
