Zum Hauptinhalt wechseln
Apples Laptop-Serie für Nutzer:innen mit höheren Ansprüchen im beruflichen oder privaten Gebrauch. Bislang gibt es Modelle in den Größen 13, 14, 15, 16 und 17 Zoll. Die wichtigsten Entwicklungen gab es beim Prä-Unibody (Original), Unibody, Retina Display, Touchbar und SOC (system-on-a-chip) Design.
20011 Fragen Alle anzeigen
MBP 15" late 2008, MBP 13" Early 2011 keyboard swap?
I have an International English (vertical Enter key) MacBook Pro 15" Late 2008, and my girlfriend has an Early 2011 MacBook Pro 13" with a German keyboard, with a keyboard with the same shape keys. Our needs have changed, and we are considering switching computers, but we each want to retain our keyboard.
Being reasonably handy and careful, and having access to the right tools, would it work to simply switch the two keyboards?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
This question was migrated from http://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sorry no they are very different internally.
War diese Antwort hilfreich?
Bewertung 0
If both Macbook's were 15" or 13" then you could swap them, provided the layouts match. You can't swap a 15" for a 13" keyboard or vice versa, as the keyboard connector is in different places.
Bewertung 0
1 Kommentar:
Up to a point ... Not all 15" keyboards are interchangeable. But it turns out, so far the 13" models are. The only rub with this is some keyboards are secured with rivets vs screws or a combo of both! The metal plate is different between each of these.
von
Antwort hinzufügen
CarstenW wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 247
