Zum Hauptinhalt wechseln
Model A1225 / Mitte 2007 und Anfang 2008 / Core 2 Duo Prozessor mit 2,4 /2,8/3,06 GHz
433 Fragen Alle anzeigen
Is it the video card?
Boots up ok, perfect display. After 5 to 10 minutes screen develops a whole screen-full of 'sparklies' and unable to get response from keyboard or mouse. Power supply checks out ok. I'm guessing that this is a thermal-related issue of a component somewhere on the video/graphics card?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
8 Kommentare
Try connecting an external monitor to your system to see if it shows up on the external if it does you nailed it as being aGPU problem, if not then the LCD or the LVDS cable has an issue.
von
Thanks to Dan. Living on the Greek island of Skopelos restricts your economic choices
von
Dan is spot on with the video card comment, however I've also seen these symptoms occur with logic board failures as well.
von
Alastair, we understand your difficulty, but can you connect it to an external monitor?
von
I spent some time on holiday in Skathos when I was much younger. Do you ever get a chance to go over to Peristera? I think thats the island that Pythagoras helped in creating a aqueduct tunnel though a large hill for a village.
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would definitely say its the graphics card it could be heat or a problem with the circuit in the graphics card
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Have managed to acquire a couple of freezer aerosols from the mainland, so detective work will start in a week or so. Thanks to all for the input.
Dan, 'my' island, Skopelos, is far prettier than Skiathos! Look me up someday.
von
Antwort hinzufügen
Alastair wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 292
