Zum Hauptinhalt wechseln
Reparatur und Unterstützung für den zur PS3 gehörenden Kontroller. Er kam 2008 heraus, besitzt einen Lithium-Ionen Akku und eine Sechsachsensteuerung. Der Kontroller (CECHZC2) ist leicht zu reparieren.
157 Fragen Alle anzeigen
Spilt coffee on ps3 wireless pad
Hi there as listed in title I have had an accident with ps3 wireless controller and a cup of coffee and now it will not turn on or charge or anything really. I have split open and tried to clean insides buttons, board etc with cotton buds and alcohol gel best i could which has got rid of the stickyness and loosend up buttons but still nothing happening power wise ie won't turn on light up or charge , is there anything I can do to try and fix it or is it a case of buying a new pad? Cheers
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar:
Ah right ok, ill strip it down give it a try thanks
von
Einen Kommentar hinzufügen
1 Antwort
Hi Anthony, I am afraid it may be death by Caffeine. If it wont charge its likely the charger components and/or the battery are kaput.
Perhaps trying an alternate power source to bypass the battery? Sometimes I find stripping to the bones and soaking all parts including the board in washing up liquid ( liquid soap) and hot water helps. Of course rinse and drying thoroughly after is a must.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Anthony wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 361
