Can memory be upgraded with 800 MHz DDR2 6400 modules?
Apple ships this laptop with memory clocked at 667 MHz (DDR2 5300). Is it possible to upgrade it with one running at 800 MHz (DDR2 6400)?
Ist dies eine gute Frage?
No - stick with the recommended speed and type.
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
After installing the 800 MHz (2+1GB) the laptop wouldn't boot - it kept on restarting. I reset the NVRAM and it started normally. Running Apple Hardware Test (I checked the 'do extensive tests' checkbox) showed no problems and it has worked fine since then.
DDR2 6400 supports 5-5-5 CAS timing of DDR2 5300, so it can be used to replace the latter.
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 225
