Zum Hauptinhalt wechseln
Toshiba’s Equium A210 laptop is a business-oriented version of the Satellite Pro A210 and Satellite A210 laptops.
3 Fragen Alle anzeigen
Frage geschlossen
Why does my laptop freeze?
Why does my laptop freeze, then blankout the screen.No response from anything.Press & hold the power button to reset, then reboot.2 or 3 times a day.
Bobby
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
The #1 reason for "freezing" is CPU lockup, usually from heat. Dust can collect around the heatsinks and fan, limiting heat dissipation.
War diese Antwort hilfreich?
Bewertung 3
Have a hardware repair service replace NEC / TOKIN 0E128 OE128 capacitors as stated in:
http://www.docstoc.com/docs/79472760/NEC...
This has solved the problem with already two Toshiba laptops.
Bewertung 3
Check your power settings - Some computers do not like to be put on stand-bye. Does it happen while you are working? What are the specs of your system?
Bewertung 1
well sometimes u can try getting your penis and sticking it up your dads *@!, it sometimes works
Bewertung 0
scroo you
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 2,971
