Zum Hauptinhalt wechseln
Herausgegeben im Oktober 2008 / 2,4, 2,53, 2,66, 2,8 oder 2,93 GHz Core 2 Duo-Prozessor
376 Fragen Alle anzeigen
Frage geschlossen
LED driver board interchangable with pre-Unibody MBP?
Is it possible to put the MBP A1260s LED driver into my new Unibody MBP?
My eyes are pretty sensitive to PWM and I can't stand the flickering, if I turn down brightness. I get eye strain pretty easily.
But somehow I didn't notice the flicker on my old MBP with LED-backlit glossy screen.
So it would be great to put the old driver into my new MBP.
Or is it the screen itself?
Old screen: LTN154BT03
New screen: LP154WE3-TLA2
What do you think?
Thank ou for answers!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I doubt replacing things here will improve things. The oscillation of the backlight LED's across all of the systems is the same (no difference in the circuit design). While the intensity is higher the flicker is less when you have the display at full brightness
CFL backlit displays are in fact a little less harsh as they have enough afterglow to smooth out the harshness when at full brightness.
Have you spoken to your Ophthalmologist or Ophthalmic medical practitioner? Heres some info on Photophobia. I my self suffer from it (I have light blue eyes) and I wear tinted glasses with an antiglare coating. It made a big difference as I need to stare at a screen most of the day. Don't forget to work in a well lit area with indirect lighting so you don't get the glare (no bare or vented bulbs shining at you). And lastly, have the wall behind your display a mid brightness color (light brown). White or brightly colored walls make things worse and busy prints or large different colored patterns also don't help (even color).
War diese Antwort hilfreich?
Bewertung 2
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 142
