My Screen show some vertical lines
in a particular area it always shows vertical green lines.
Ist dies eine gute Frage?
Anoop, it would help if you would post an image with you question. From your description, it does sound like a TAB error and can only be fixed with very special (and expensive, tools. If it is a tab error, the best fix would be a replacement.
War diese Antwort hilfreich?
It can either be a hardware of software problem, lets check it one by one. First try to download the updated driver from your machine`s manufacturer`s website then install it. If the problem still persist then its defiantly the hardware level problem which is caused by faulty LCD cable of r joint so you can further take it to some hardware shop.
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 13
Insgesamt: 784
