Zum Hauptinhalt wechseln
Ein 15,4-Zoll Windows XP Laptop, der 2006 von Dell veröffentlicht wurde
My computer has been really slow for about three months?
I have had my Dell Inspiron 1501 for about three years and has been really slow here lately, I have had it fixed a couple of times. Yet, it is still being very slow. Also when I start my computer it tells me that it can not read my battery, and to press any key. Another thing it is having a hard time charging as well. Is there something that they have messed up on it or is it something I have done.?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Run ATF-Cleaner and CCcleaner, free sharewares available on internet for download, in your
system for broken registry links , clearing cache and temporary internet files etc. Also you
can increase virtual memory size of your windows to speed up your PC.
To increase Virtual memory please follow the steps below.
1. Open Computer Management.
2. In the console tree, right-click Computer Management (Local), and then select Properties.
3. On the Advanced tab, under Performance, click Settings.
4. Under Virtual memory, click Change.
5. In the Drive list, click the drive that contains the paging file you want to change.
6. Under Paging file size for selected drive, click Custom size, type new paging file sizes
in the Initial Size (MB) and Maximum Size (MB) boxes, and then click Set. Click OK.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Clean your the easy way with clean my PC.
- You can run "sfc /scannow" command
- You can remove temp files.
- You can run clean mgr
- You can remove pref etch files.
- You can uninstall unwanted software .
- You can remove all the dust from your PC by blower. for more visit Top 10 tricks(Quick And Smart steps) to Speedup your computer
=> Find resource-hungry programs.
=> Close system tray programs.
=> Disable startup programs.
=> Reduce animation.
=> Lighten your web browser.
=> Scan for malware and adware.
=> Free up disk space.
=> Defragment your hard disk.
=> Uninstall programs which you don't use.
=> Reset your PC / Reinstall windows
Bewertung 1
There are lots of little things that slow down a computer, mostly it is programs that are running, but day to day clutter can slow your computer down too.
A good thing to try is to download a good program like Ccleaner or Reginout. I personally Use Reginout because i don't believe on free products.
It will analyze your computer, and clean up all that it can safely clean, inducing your registry.
It works well, and is 100% reliable.
Bewertung 0
if your pc slowdown check the the heat sink grease if its dried up. your pc slow down as it mean to say its overheating. no program can repair it.
replace your heat sink grease. i recommend arttic silver 5
Bewertung 0
check the background program running in your computer.you can see on the right side bottom of your screen.that is cause also to slowdown your computer.to disable all of that
click start button on the left side of your screen and then write MSCONFIG and then theres a small screen come out click STARTUP and then on the bottom disable all and restart your computer see if theres any changes.
Bewertung 0
Antwort hinzufügen
Amber Wilson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 4,045
