WARNING: YOU MAY LOSE ALL YOUR DATA BY DOING THIS.
Issues:
- Account sync OFF permanently with the message: "Sync is currently experiencing problems".
- Signing in Google Apps fails showing message: "Can't establish a reliable connection to the server"
Possible Cause:
- system file named 'hosts' (/etc/hosts) points to a Google server that changed IP, thus blocking access to Apps.
Possible Solution:
- edit 'hosts' file (/etc/hosts) deleting or commenting (adding a # at the beginning) the old line
I have a Samsung Galaxy S AnyCall M110S with GFAN WF07 SP 8 XDA Version i tested it and it worked...
It may be work on any android device.
Please do it at your own risk.
How to do it:
METHOD 1
1.- Root your device (of course)
2.- Editing the file
You will need a proper editor
On your device open your browser and go to: www.ghisler.com/android.htm
Download and Install Total Commander for Android... and open it
OR DOWNLOAD BELOW
3.- Browse with Total Commander to root/etc
(hint: on the right side of the screen there's a shortcut to system folder.. look for etc/ and you will find it)
Long tap on "hosts" > edit file > Totalcmd-Editor
Open etc/hosts and edit the file. Just put # before 74.125.93.113 android.clients.google.com.
4.- SAVED
Edited file should look like this:
127.0.0.1 localhost
#74.125.93.113 android.clients.google.com
remember: based on my own observation it should be look like this:
127.0.0.1(just one space)localhost
#74.125.93.113(just one space)android.clients.google.com
5.- Turn OFF your device.
6.- Got it on Recovery Mode
7.- Factory reset, wipe data.
8. Reboot your device.
9. Once the phone reboots, input your google account information when the phone asks for it.
10.- Sync to your account and contacts
METHOD 2:
1. Make sure you have a ROOT ACCESS on your Device.
2. Install Root Explorer, Run App, Grant SU Access.
3. Browse root / etc... at the top of your screen you will see mount R/O and mount R/W...
4.Tap mount R/W
5.Look for host file, long press it and open with text editor.
6. just Add # (pound sign) on the first number.
like this:
SAVE IT and Reboot.
Now you can connect to Google Play very well.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
48
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
what if my phone reboot it can be korean language ?
von Vanessa Canua
