Anyone know where to buy antenna relays?
One of my battery connector screws was stripped, in the process of getting it out, my friend slipped and scraped a flat screw driver across the logic board, which scraped off a few of the antenna relays, now I have no signal. I really miss my iPhone :( does anyone know where I might be able to purchase relays without having to buy a whole logic board or even a service that will fix it?
Ist dies eine gute Frage?
Bewertung
0
Can you post a picture ?
von [deleted]
Lisa, you are talking most likely about different SMD components, not relays. Like iraffbe said, attach some images. The other issue with this will be, do you know how to solder? How did you want to attach the components?
von oldturkey03
I do know how to solder. I have previously fixed regular sized computers, ecm on a lexus sc400, lcm on a crown vic, ect ect. I suppose as far as attaching the components, I will use a braid and desolder the ones that are on it, I have already borrowed an awesome device from my aunt, it is basically a magnifying glass with a lamp on a hinged arm, where you can adjust it, then let go and have 2 hands on your project, so I suppose I will attempt to solder the new ones in the same place the bad ones are now, with rosin core solder of course. I have not yet done anything with an iPhone. Is it the same? Or are there other differences that I will need to know?
von Lisa
Here is a photo, I hope :)
von Lisa
Not sure where you image went:-) Check this guide Adding images to an existing answer for help with that. Most likely you will have some SMD components that need to be soldered back on. Anyhow, an image will help to identify what parts came off your board.
von oldturkey03
