Zum Hauptinhalt wechseln
Herausgegeben im Oktober 2008 / 2,4, 2,53, 2,66, 2,8 oder 2,93 GHz Core 2 Duo-Prozessor
376 Fragen Alle anzeigen
Hang, does not start
Hi
I have a problem with my MacBook Pro 5,1 2.4 GHz Intel Core Duo.
When I shut down, or restart, the system hang..
There's no noise of the DVD drive, but the activity lamp in front is on (after few seconds off, then on again and stay's on).
If I wait for several hours, it will start without problems and run properly...
Anybody any ideas, where's the problem???
Thanks a lot!
Update
Hi Machead3
Thanks fpr your input.
I installed everything...
It look like the Mac has the know problem with graphic card... It does not hang... I just have a black screen...
Thanks' anyway.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Run AHT - try tools-> repair disk. Also Disk Utility->Repair permissions. Sounds like you have either corrupt preferences, permissions or eminent disk failure (hope you have/keep a current backup of any valuable files - not apps just data that would be a PITA to repalce/recreate.)
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hi Machead3
Thanks' anyway.
von
Antwort hinzufügen
AWI wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 110
