Zum Hauptinhalt wechseln
Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1273 Fragen Alle anzeigen
vertical lines across screeen of notebook toshiba qosmio
The screen of the desktop is crossed by a number (exactly 14) of vertical lines large about 1 millimeter of different colors.The device works well but the vision with those lines troubles me. Agostino Torre
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
sounds not that great - but let's start with plugging the qosmio to an external monitor to rule the graphics card out.
here is a great comparsion of screen failures - but i think you's is example 2 with more lines.
here are a few guides for the qosmio's
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
This happened to a friend of mine. Try lightly twisting the display frame. If the number of vertical lines changes or if some disappear and new ones appear then you will have to replace the LCD screen.
Bewertung 2
The graphics chip on the X505 series and a few others tend to overheat and this causes the solder joints on the motherboard to crack and fail. New motherboards are available on ebay. There are also repair services to reflow the solder joints. You might even be able to repair it yourself with a heatgun like people do with RRoD Xboxes but that's probably above your skill level.
Bewertung 1
Antwort hinzufügen
agostino wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 3,344
