Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2,53 GHz Core 2 Duo Prozessor
170 Fragen Alle anzeigen
Frage geschlossen
Mac freezes for about 1 min and goes on
I replaced the 250GB hard-disk by a flash-drive with the same capacity. I took out the CD/DVD-drive and replaced it by a 1TB hard-disk drive. Since that the mac is running much faster but it freezes up randomize with out any message or indication. It's indicating my work but it's very annoying being interrupted. Does anyone having the same experiences and may can give me advice?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You maybe facing the SATA I/O speed issue. Check you SSD & HD's specs see if they are SATA II (3 Gb/s) not SATA III (6 Gb/s) if they are you'll need to check to see if the HD has a jumper to slow the I/O down to SATA I or SATA II speed. In the case of the SSD you may need to set the I/O via firmware or will need to change out the SSD to a slower SATA II version.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you very much, that sounds logical. So I did some research regarding the SanDisk X110 256GB I putted into my Mac. I capable to run up to SATA III. I couldn't find any description how to slow it down. Does may anybody know how to do? Many thanks in advance.
von
Check your HD as well here
von
I tried to get further information of the net but hasn't been successful until now. What do you mean with "here". Many thanks in advance.
Bewertung 0
1 Kommentar:
'here' is just a manor of speech. In this case don't forgot to check your HD's SATA speed as well (here).
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 128
